I know why my fan runs constantly
Old Jun 20, 2005 | 02:34 PM
17wth85z28's Avatar
Car: hmmm, camaro site.....
Engine: 305.... TEAR
Transmission: t-5 soon
1991 RS TBI
I have found why my electronic fan stays on at all times. There was some extra wire going to my fan motor and then to the main harness that enters my firewall. They shaved some of the wiring harness and wrapped wire around bare wire. Ran that to the main harness and shaved several wires. They found a ground which is on when the key is on, and then my fan runs. It has a new fan switch and the wiring to that is kinda screwy. I am gonna solder it and shrink wrap it to bring it back to safety.
I am going to try and do some rewiring tommorow and see if it helps. All of the wiring is still in my car. Relay clicks, but you can unhook it and the fan will still run. I need a very complexe wiring diagram for this. Someone who has it, can you post it or email it to me. PM for my email address.
Hope this post makes sense.
Old Jun 20, 2005 | 05:46 PM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
well not sure if this will help but ...i think it might send you in the right direction
Old Jun 20, 2005 | 07:15 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
do you notice that your car runs cooler with the fan running all the time?...i was thinking about setting it up to have my fan run all the time
Old Jun 20, 2005 | 09:09 PM
17wth85z28's Avatar
car does run cooler, but it also runs below 180 on cold nights most of the time it doesnt go even get to the mark after 100 if its cold.
Old Jun 21, 2005 | 03:04 PM
17wth85z28's Avatar
Fan now cuts on when it is supposed to. re ran some of the wires and cleaned my relay contacts. It does get hot and I can deal with it. Most likely going to put a low temp switch and thermostat in it soon. Might even replace the fan motor to a new one for insurance reasons. Or just upgrade to a better fan, something aftermarket.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
jbd1969
Aug 17, 2015 07:06 PM
TA8487
Aug 16, 2015 12:21 PM
