Can a y pipe?
Old Aug 3, 2005 | 11:19 PM
90tbi305's Avatar
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
Can a y pipe?
Well i think that my y pipe can be tuching my oil pan. Can this be a reson my car could be running a little hotter? I just installed it about 4 days ago and started to see the change. -Eric
Old Aug 4, 2005 | 12:31 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
That would effect oil temperature (if anything), not coolant.
If the equaling headers are new as well, try guessing alont the lines of heat emitted by the primaries is toasting the sensor.
Old Aug 4, 2005 | 01:02 AM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
What?
Old Aug 4, 2005 | 01:04 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Where is the sender for your temp gauge located?
Old Aug 4, 2005 | 03:11 PM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
Its on the head by the 1/3 spark plug
Old Aug 21, 2005 | 07:56 AM
michta's Avatar
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
You may consider moving temp sensor into intake manifold if a provision is there near the t-stat housing.
I have a 84 ta w/350 auto and hedman tubular exhaust system and temp runs around 200 with a 190 t-stat. Y pipe is close to oil pan but not touching. When tightening collectors needed to hold down on y pipe to get some clearance from pan.
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
