89 RS, no condensor fan with A/C on
Old Aug 15, 2005 | 09:25 PM
hotrod53's Avatar
I had to jump out the electric fan in order to run and charge the AC. Shouldn't the fan come on any time the A/C switch is on? If so, where is the relay that makes it happen? This car is a rebuild, so anything is possible. The fan does cycle if you let the car run, but the high side pressure was hitting a whopping 200 PSI! When I jumped the fan, it dropped right down where it should be. I was shooting hot gas right through the condensor! Any help appreciated!!!!
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
