Please HELP me!!
Old Aug 28, 2005 | 10:02 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Please HELP me!!
Hello everyone, okay my car runs hot (of course.) I will crank it in my driveway and let it sit there for 10-15 mins. and it will be a 210 degrees and i never let it get past 220. I cant figure out what is wrong with it, but here is what i have on the cooling system (its all NEW!) Okay, i have a Be Cool radiator, Perma Cool 16" fan (like 2300cfm, i think), Stewart stage 2 water pump, and a water restrictor (instead of a thermostat), and the fan runs all the time. It has 100% water in it and one bottle of Wetter Wet, also new hoses, new Cylinder heads and intake. The only thing i can figure is the fan i just not pulling a great enough volume of air through the radiator. Any suggestions?? Thanks for any help!
Old Aug 29, 2005 | 01:37 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
are you useing coolant? I dont know cause you said that your using 100% water.... Maybe there is a small leak and air is getting in there some how not alowing it to burp. Just double check everything and even do a leak test to make sure its all cool. hopes this helps a little bit.
Old Aug 29, 2005 | 07:28 AM
BT283's Avatar
how can you leak test it?
Old Aug 29, 2005 | 10:43 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Go to your parts store and ask for a coolant pressure-tester. They let you borrow it for around $35bucks. Try this link out bro...
Pressure-Tester
Old Aug 29, 2005 | 10:45 AM
BT283's Avatar
How much pressure should it have?
Old Aug 29, 2005 | 12:36 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Just pump it up and watch for a pressure decrease.
Old Aug 29, 2005 | 04:45 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Old Aug 29, 2005 | 07:31 PM
BT283's Avatar
I will try it tomarrow, although i dont think this is my problem, i think the fan just doesnt pull enough air, anyone else ever experince this problem?
Old Aug 29, 2005 | 07:42 PM
BT283's Avatar
Im also thinking of going to a dual fan setup any suggestions or comments or an idea of what ones to get thanks.
Old Aug 30, 2005 | 09:11 PM
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
make sure the fan is blowing the right direction. if it is not, swithching the wires to the motor will fix it. i think 2300 cfm is a little short, also.
Old Aug 30, 2005 | 09:13 PM
BT283's Avatar
i pressure tested it...no leaks. And i did reverse the wires today and put a plastic bag to it to see if it was pushing or pulling and it was pulling so i check that, but what do you mean 2300cfm is a little short?
Old Aug 30, 2005 | 09:27 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
2300 cfm is fine.
Old Aug 30, 2005 | 09:30 PM
BT283's Avatar
my opinion is that 2300cfm is fine but i dont think mine is pulling that, is there anyway it could just be running a half power. And i forgot about this the other day went a cranked my car and it got warm faster than usually, and the fan wasnt coming on, but the next day it worked again
Old Aug 30, 2005 | 09:59 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Do you have a stock fan switch? The stock fan switch won't turn the fan on until about 230*. GM designed our cars to run hot so they would put out less emissions.
You can try a lower temp fan switch. If you think your fan motor is not doing the job, they are not expensive to replace.
The dual fan setup should help. One fan will be hooked up to the fan switch. The other can be wired to a manual fan switch on the dash. That should help bring the temp down a bit.
Old Aug 31, 2005 | 07:26 AM
BT283's Avatar
I no longer have a fan switch my fan is grounded so it will run all the time, and i have a perma-cool fan so i cant just replace the motor
Old Aug 31, 2005 | 04:53 PM
bowtienick's Avatar
did you use a relay to control the fan? long wires and high amperage dont always do so well. before i knew how to use a relay, i had long wires to a switch inside, and i burnt up a couple of fans
Old Aug 31, 2005 | 05:03 PM
BT283's Avatar
all i did is just splice the wires in to the factory location and ground the green wire to the body.
Old Sep 1, 2005 | 07:13 PM
BT283's Avatar
Fan quit working again today, and it looks like burned up relay, so i am probably going to just rewire it to the ignition switch, any advise. Im doing it tomarrow so i kinda need any advise soon please, Thanks alot!
Old Sep 2, 2005 | 05:22 PM
bowtienick's Avatar
wire it through a relay like this:
power from battery to relay, from relay to fan then to ground on the switch side. go from an ignition switched spot in fuse panel to relay then to ground on the coil side
that will run your fan any time the key is on.
