Sensors - 2??
Old Sep 8, 2005 | 04:52 PM
Chuck's Avatar
Sensors - 2??
It seems there are 2 sensors for coolent on my
350: One underneath block on passenger side -
and one on top of intake manifold in front of TBI.
Which is what?
Thanks!
Chuck
Old Sep 8, 2005 | 04:54 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The one on the passenger side of the block isn't a coolant sensor. That is the knock sensor. The passenger side cylinder head, however, houses the fan switch (which is a form of temp sensor). The one on the intake manifold is the coolant temp sensor (CTS) that the ECM uses.
Old Nov 10, 2005 | 12:31 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
ok so there are 4 sensors on the heads and block. the oil pressure sensor above oil filter, knock sensor on pass side block, and one in each head.
i know the drivers side head sensor tells my gauge what temp the car is at but since im getting a entire new fan switch can i do away with the sensor on the pass side head??
Old Nov 10, 2005 | 12:36 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
That would be the old (factory) fan switch, so yes.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
