Shrouded electric fan
Old Oct 1, 2005 | 08:52 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
This may belong on the fabrication board, but it probably belongs here more.
I have an 85 TA with a fabricated single electric fan and a huge Griffin aluminum radiator. The Griffin is almost 2¼" thick and barely fits. Because of this, the fan is a pretty decent distance away from the radiator.
I've noticed that the car is starting to heat up more than I am comfortable with (215-230*) while idling with the AC on. It wont get much hotter than that, but I dont like to have to keep glancing at the gauge.
I was thinking that a fan shroud to help draw air more directly from the radiator might help. It would be easy enough to make out of aluminum or plastic. Does anyone see a downfall to this? I was a little concerned about it blocking air at high speed.
BTW, the fan is a factory thirdgen single puller.
Thanks!
-Corrupted
Old Oct 5, 2005 | 03:08 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
A fan shroud should always be used if the fan is more than 1 inch away from the radiator.
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
