Reservoir cap
Old Oct 19, 2005 | 10:11 PM
305TransAm-84's Avatar
Car: Pontiac TransAm -84
Transmission: TH700R4
Reservoir cap
Yesterday I checked coolant level in reservoir tank. I had to fill 0,5 litre (1/8 gallon) water to rise coolant level away from min. level.
At the same time I study the cap on this tank. It had a ventilation hole (small finger size) at top. I searched forum and found that this is correct.
But it didnt had any valve or any pressure regulator her. Just a top-lid.
Is this normal/OK for cap?
And: With this solution you got to expect some evaporating of coolant from reservoir tank, aint ?? (Even if it has no pressure or very high temp.)
Old Oct 19, 2005 | 11:10 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Just a cap is normal as the pressure is controlled by the radiator cap on the radiator. My cap doesnt have a hole in it. Its just a normal sealed cap.
Old Oct 23, 2005 | 07:39 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
My 89 and 86 both have the hole. It would just blow the lid off if you ever overheat and you'd have to find it. You're not going to lose much fluid over such a small hole.
Old Oct 24, 2005 | 03:45 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
Well think about it for a minute. If the holes were not there, the air in your overflow tank would not vent and make room for the coolant when the overflow tank fills up.
sheachopper
Jul 31, 2019 11:27 AM
Fireslash
Apr 11, 2016 06:43 PM
school boy
Oct 22, 2015 11:47 AM
LT1Formula
Oct 8, 2015 08:34 PM
Damon
Sep 26, 2015 04:29 PM
