Thermos
Old Dec 8, 2005 | 04:00 PM
CamaroKillsAll's Avatar
Car: 88 RS
Engine: 5.0 TBI
Transmission: 5sp
Thermos
Where is the thermostat for the rad fan located?V6 engine
Old Dec 8, 2005 | 09:37 PM
Frank89IROC's Avatar
Follow the upper radiator hose to where it connects at the top of the engine (usually at the intake manifold) the hose should connect to a "housing" that has either 2 or 3 bolts holding it down. Remove the bolts & the thermostat should be inside that housing. To access the bolts, you may need a swivel adapter or swivel wrench. Now if you are referring to the "sensor" that sends the signal to turn the electric fan on, it's located at the rear of the engine in the passenger side exhaust manifold, in front of the "cowl" area.
jaridjohn
Oct 5, 2015 07:01 AM
88'camaro305TBI
Carburetors
Nov 19, 2001 06:10 AM
MTCAMARO
Carburetors
Sep 1, 2001 11:08 AM
88'camaro305TBI
Carburetors
Jul 24, 2001 10:32 PM
88'camaro305TBI
Aftermarket Product Review
Apr 14, 2001 10:15 AM
