Radiator Leak..
Car: '92 RS
Radiator Leak..
Found where I was leaking coolant
The radiator seems to have sprung a leak on the plastic side piece behind the upper radiator hose. Probably because I replaced a worn out water pump and thermostat. The location of the leak is next to a mounting point. Pin sized, but sprays hot coolant into my headlight housing
Would it be possible to JB weld the area to seal leaks? Because of the location I don't know. I'm sure the area saw a bit of flex from dips, potholes, speedbumps, driveways, ect. If it's possible, could a product recomendation be made?
She loses approx. 2 pints of water each day (driving only when necessary) The resivoir is always nearly bone dry. Replaced tstat w/ a 180, which doesnt open until about 210. I am assuming this is normal, because stock turn on is 234?
Heres to hoping this will solve my cooling troubles.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Most people say to drain coolant below the point of leak, clean thoroughly, apply sealant (JB weld I believe will work), let sit for a full 24 hours, then act like nothing happened.
