fan swich
Old Jan 8, 2006 | 04:21 PM
Irocman86's Avatar
fan swich
where are they located
Old Jan 8, 2006 | 06:37 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Under the hood, for beginners.
Give more info on the engine and someone might be able to tell you....
Old Jan 10, 2006 | 05:01 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
where would the fan switch be on my car?
Old Jan 12, 2006 | 11:24 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
welp i have a small block, cant get to mine from the top it is between the two rear plugs on the pass side head just a hair lower, if your under there you'll see the starter, right next to that is a good sized round silver module, thats the knock sensor, go straight up adn you'll see it brass deal right between the plugs.....IT makes a big mess when you pull it, i just put in a hypertech on 200*off185* i finally got a good angle at it to break it loose got it out a few inches and she started gushing, the bucket doesnt catch much as it hits the starter, ypipe and jsut about everything it can to redirect itself and make a lake in the garage....dont say i didnt warn ya
Old Jan 13, 2006 | 11:17 AM
GTA89's Avatar
Car: Pontiac Trans Am GTA
Engine: 5.7 350
Transmission: TH700R
hahaha how funny,
the same problem here
https://www.thirdgen.org/techbb2/sho...32#post2697032
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
