Where does this hose go to and what does it do?
Car: 91 camaro z28
Engine: 6.3L, heads, headers, cam,.....
Transmission: 700-R4 w/shift kit and 3-4 WOT kit
Axle/Gears: 4.11
Hey guys I need some help.
Ok I found this pic here at thirdgen.org and I am using it as a reference for you guys to look at to make my question easier to understand. OK in the pic hose 1 where does it go to? And is it necessary to have this hose? The reason that I ask is because I got a new radiator and it does not have a place to connect hose 1 to the radiator. Any feed back would be greatly appreciated. Thanks you guys.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
From the picture I believe the hose you labeled #1 and #3 are the ends of the same hose.It goes to heater control valve.TPI cars had a coolant hose that ran to the underside of the throttle plate which appears to be #6
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
You might have tried to find a picture of a later serpentine-belted car for reference.
The hose marked #1 should run from the steel pipe to the radiator. #1 and #3 should not be the same hose in stock routing.
What radiator did you buy? Company and part number? If it's missing that fitting then it does not sound like a direct replacement piece.
Do you have the factory oil cooler?
Here's a drawing for reference. Look at the routing on the left for your '91. If you have the cooler, the hose you asked about leads to a steel pipe for it.
Engine: LU5 305 CFI
Thankyou Jade that clears it for me anyhow.From the picture it appeared #1 and # would be the same hose.The overflow tank hides the steel coolant line your diagram show.And you make a good point the parts place may have goofed on getting the correct one.
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
hahaah awesome, I took that picture,, thats my engine bay.. !!
i actually am still wondering the same thing too!
- im removing all of the HVAC system, so i'm bound to figure out thos hoses,
Pac J
May 17, 2020 10:44 AM
2012sergen11
Oct 13, 2015 07:38 PM
