paint colors and heat absorption
Old Mar 14, 2006 | 01:35 PM
rsmaroo92's Avatar
Car: 1992 RS T-Top
Engine: 305 TBI/ to be replaced w/383 forged stroker
Transmission: 700R4/ coming 200 4R
This is a reply to an old post dealing w/color and heat transfer, etc. Lets go back to science 101: Black is the absence of color(i.e. reflects no color), white is the existance of all color(reflects all colors). When painting a motor, tranny, diff., etc., the darker the color, the better. Remember, heat transfers from hottest to coolest. If you are trying to promote cooling in your engine, raiator, diff, tranny, etc., a dark paint,(black), is best. Heat is just at a lower portion of the spectrum as color or light. Remember; paint is the same color on the outside where you can see it as it is on the inside(where it meets the base metal). Therefore; if you paint a motor white, it will reflect the heat of the motor back to itself, while if you paint it black, or a dark color, it will absorb the heat, and help to transfer the heat away from the hot eng. etc., to the cooler ambient outside air. One of the worst things you can do is to install chrome oilpans, oilfilter covers, etc., as all these do is to help reflect heat back into the engine![
Old Mar 28, 2006 | 06:40 PM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
Anyone have some opinions on this idea?
Sounds reasonable to me.
Old Mar 31, 2006 | 10:01 PM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
I can't speak for what the chrome plating does to heat radiation, but painting your motor white won't cause it to shed any more heat than if you painted it black. The color of the paint effects the light energy reflected, not the heat energy. A white object in darkness absorbs/sheds the same amount of heat as a black object in darkness.
Old Apr 1, 2006 | 12:31 AM
92CamaroLS1's Avatar
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
Yea the color of the motor doesnt matter. White reflects visible light not heat radiation. Different types of energies. Even if it did make a difference, it probably wouldnt even be noticable.
**Now if you have no hood and your engine is extreamly exposed to the sunlight then white paint would be beneficial at reflecting the suns visible light rays. However once again the difference it would make would be totally diminished compared to the heat the engine itself produces.
Old Apr 4, 2006 | 02:24 AM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
I can vouch for the chrome plating and its heat retention properties. My friend used to have an IROC and he decided to put a chrome alternator on the car. After about 2 months, the battery light came on. The battery checked out fine but the alt. was smoked. So he got a new chrome alt. same brand and everything. Once again, about 3 months later, alt. fried. Took it out and sent it to a repair shop. The windings were all melted and overheated. Once we finally convinced him to put a regular alt. on it, he was much happier. He still has that alt. to this day, and that was about 3 years ago.
Old Apr 6, 2006 | 02:11 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Exactly right.
Street Lethal
Apr 30, 2019 12:14 PM
69 Six Pack
Oct 5, 2015 07:51 PM
zayne0
Aug 24, 2015 07:22 PM
LT1Formula
Aug 20, 2015 09:36 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
