fan temp sensor
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
fan temp sensor
Is there anywhere else besides Summit or Jegs to purchase the temp sensor that turns the fans on at a lower temp ? Nothing against Summit or Jegs, just want to know if anyone sells them for less.
Car: 86 Camaro IROC-Z
Engine: 305 LB9
I just ordered mine yesterday from here Madvet Fan Switch Turns it on at 200 and off at 185, it came out to be like $23 shipped.
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Dont know if your into burning your own proms. But you can swap the pins at the computer. And set the fans to come on and ofF whenever you want them to. Thats what i did and it works great.
Very easy to do the hardest part is pulling the wire from one pin and pushing it into another.
FormulasOnly
Sep 10, 2015 09:07 PM
