need help!!!!!
Old Mar 28, 2006 | 09:05 AM
skinwalker's Avatar
Car: 1989 IROC Z
Engine: TPI 350
Transmission: 700R-4
need help!!!!!
I have a 89 iroc z with a 350 TPI, when the car warms up and Im driving around my temp would reach 220 or a little higher. Does anyone know what could be causing this to happen.
Old Mar 28, 2006 | 10:15 AM
Quicc Silver Z's Avatar
Car: 82 Indy Pace Z28
Engine: 383 Stroker
Are ur fans working properly? Maybe a new hose and t-stat...
Old Mar 28, 2006 | 12:49 PM
lon1986TA's Avatar
Car: 1986 TA
Transmission: Rapotr 700R4
Axle/Gears: 9" 411's
check your ground effects. I found out if you pull up on a crub and lose the front one air does not properly get directed to the cooling fan/ system
