Manual Fan Switch
Old Apr 8, 2006 | 05:42 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Manual Fan Switch
My fan switch seems to have a mind of it's own. I can turn it on and off once or twice; but after a second attempt at the cycle, it will turn on but will not cut off thru the switch. I can kill the ignition to stop the fans. The wire is not severed in any place; it is hooked to the switch securely; where it passes thru the firewall, it is wrapped in a thick roll of electrical tape; the ground is screwed tightly into the underside of the dash (metal part, of course). So then, what am I missing here?
Thanks,
Eric
Old Apr 8, 2006 | 07:55 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
May be grounded to metal, but it that piece of metal clean and grounded itself? Check it with a light to be sure.
Also, are you running the power through a relay? May be too much amperage through the switch if not.
Old Apr 8, 2006 | 08:45 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
No relay, the wire running into the switch is crimped directly into the connector (at the sensor) that has the wire coming from the fan/harness itself.
The ground is actually the metal part that the plastic panel (fuse cover area) under the steering column screws into. If that isn't a good place to ground, can you or anyone suggest a better place? Along those lines, can someone explain why it will work a couple times and then refuse to turn off?
Old Apr 9, 2006 | 04:44 AM
BlackThunder's Avatar
Car: 1988 Pontiac Firebird Sport Coupe
Engine: 350TPI V8
Transmission: TH700 with o'drive,TCL, WS6
Axle/Gears: Borg Warner Posi 3.27:1 ratio
I agree the most likely cause is too much current going through the switch contacts, overheating and making them sticky. I'd be inclined to fit a suitable relay to do the switching of the fan and just use the switch to flip the relay.
Old Apr 11, 2006 | 07:36 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Thanks for the replies. The solution was the ground. It was hooked under the dash; I removed the kick panel, drilled a hole, and installed it there. Problem solved. My switch can handle 20 amps/120-some-odd volts so I don't think the switch was lying down on me.
Thanks again, hope this will help somebody else with this mod.
Eric
89GTAOz
May 16, 2020 09:31 AM
krisner89
Oct 10, 2015 06:03 AM
bryanwood74
Sep 24, 2015 09:50 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
