Radiators blown
Old May 11, 2006 | 09:54 AM
Slow2.8's Avatar
Radiators blown
I've been leaking coolant for a while, believe its the radiator (drips right below it) Now this morning i filled it up with water/ antifreeze let i run for 10 mins and starts smoking from the radiator, so i know i gotta replace it now. What radiator will fit in my 89 2.8? I've searched with no results.
Old May 11, 2006 | 11:08 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Just get a factory replacement from a local parts store.
Old May 12, 2006 | 09:11 AM
Slow2.8's Avatar
Thats what im getting, an aluminum one tommorow, any tips on installation? I know to use liquid wrench on some of the lines, im going to soak them tonight. Any other tips to make it easy?
Old May 12, 2006 | 12:57 PM
ChrisColeman's Avatar
Might wanna get Radiator hose's. That might even be the cause of your leak. Maybe some new hose clamps. Installation is a breeze. Unbolt the two bolts above the fan going into the fan shroud and the 4 on top of the core support, Lean the fan back out of the way, Undo the lines and hoses and pull the radiator right out. You might have to get a boxed end wrench.. (fuel line wrench) not sure of the name.. if the tranny lines are a little to tight.
Old May 13, 2006 | 01:08 PM
Slow2.8's Avatar
Upper radiator hose is in good shape, im replacing the lower hose though.
Have the fuel line wrenches too and soaked the lines with liquid wrench. Whats the easiest way to get the hoses off? without cutting them!
Old May 13, 2006 | 03:25 PM
k's89rs's Avatar
Car: 89 rs, bmw 325 is
Engine: 360 (.060) 2.5L inline six
Transmission: 700r4, 5-speed
Axle/Gears: 9 bolt 3.08 3.? limited slip
make sure you get those tranny cooler lines back in GNT (good n' tight). other wise you will leak fluid all over the place. also take your time and get the threads lined up correctly, if you encounter any resistance going in, STOP, and try again. cross threaded line fittings are not fun!
Old May 15, 2006 | 11:59 AM
Slow2.8's Avatar
well the radiator and hose are in, looking good, running great!
sheachopper
Jul 31, 2019 11:27 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
