manual fan switch
Old May 14, 2006 | 08:48 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
manual fan switch
does anyone make a manual fan switch for 3rd gens? i have seen them for 4th gens (like Slp makes one) but none for 3rd gens.
Old May 15, 2006 | 10:05 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
It's pretty much one of those "make your own" type of deals.
Old May 15, 2006 | 06:11 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
BE COOL
Originally Posted by FormulaL98
does anyone make a manual fan switch...........
Don’t forget to make it look as cool as it’s gonna keep your car(s)
In mine I’m using a small pushbutton that lights up a cool
blue LED. It takes almost no space on the
instrument console.
“If people drove any slower
they’d be going backwards.”
NINÅ
Old May 17, 2006 | 09:58 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
I used a fog light switch from a TransAm for a manual fan switch. Get one at the junk yard that matches what you have in your dash. I mounted it in the middle of the dash under the temperature gage. There were plugs there already for extra switches, just replace one with the new switch. I was mounting a second fan, manually controlled. Wired from the fuse panel, switch activated hot to the new fog light switch, out of the switch to a relay located by the radiator. (splice into the output wire on the switch and loop back into the switch to make the light on the switch turn on when the fan is on). Looks like factory installed.
Old May 19, 2006 | 05:54 PM
ron reece's Avatar
Car: 92 B4C/1LE CHP camaro 06 vette LS2,
Transmission: iroc, 700r4, auto
i just wired mine to both come on when the engine is on. that way you don't ever forget to turn them on. my car runs at 180 all the time.
89GTAOz
May 16, 2020 09:31 AM
krisner89
Oct 10, 2015 06:03 AM
bryanwood74
Sep 24, 2015 09:50 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
