Blown A/c
Old May 21, 2006 | 04:10 PM
Harley61's Avatar
Car: 90 RS / 89 IROC
Engine: 305 TBI / 305 TPI
Transmission: 700R4 / T5
Axle/Gears: 3.73 / 3.08
Blown A/c
On my way home Friday, I had the A/C on and all of a sudden smoke started coming through the vents and smelled like burned plastic. I pulled into a parking lot and smoke was coming from under the hood. When I checked, the a/c pump (where the belt is) looked fried. I started it back up and the belt spins with some noise and it got me home. Can I run the car like this??
What should I do now? I just put a bunch of money into fixing other parts of this car so my car fund is VERY VERY low. Any sugguestions? Thanks
Old May 21, 2006 | 04:46 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
It sounds like your clutch bearings are going(at the very least).You can replace the clutch assembly itself or just the bearings & seals.I take it you ran the rest of the way home without A/C.If your clutch is making noise I would remove the A/C belt until you can repair it(unless your'e running a serpentine setup).I ran into a similar problem a couple days ago but mine is a little more complicated.The clutch is fine but my compressor is locked up.I disconnected the clutch lead so it doesn't come on when I turn the vent on.
Old May 21, 2006 | 05:01 PM
Harley61's Avatar
It's a serp setup. It seems to spin fine but makes some noise. Is it safe to drive? It looks like the front of it (clutch?) is fried up. If I don't turn on the a/c would it be ok to drive?
Old May 21, 2006 | 05:05 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Yup, had the same problem. No smoke but loud squealing noise. I shut off the A/C and the noise went away. I removed the belt and ran a jumper wire to the A/C clutch to energize it and it would only turn 1/4 of a turn. I bought a rebuilt comp. with clutch and converted to R134. I kept the old comp. and cut it open and it was perfect inside but out of oil. If I would of known I would of added some oil and saved it. Bummer!
Auggie
jrdturbo
Mar 31, 2016 02:58 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
383backinblack
Sep 25, 2015 11:31 AM
