no heat/cooling fan stays on
Old May 22, 2006 | 06:10 PM
87irocz28_383's Avatar
Car: 87 iroc z28
Transmission: 700-r4
Axle/Gears: 9-bolt, 3.27 gears
ok i did a search and couldnt really find an answer,
but heres my problem the fan comes on as soon as i turn the key, even in the mornin i dont have to start the engine jsut turn the accesories on. and my temp will just barly gett past 40 and never any higher..i tried outt the heat and i get none...so i am thinkin i have one of them fail safe thermostats or sumthin (i just got the car lil while ago) should i try the new thermostat?
any help would b appreciated
Trevor
Old May 22, 2006 | 09:34 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
might not help you at all but a couple weeks ago i removed my a/c system, and there were 2 sensors that i had to remove also as they were part of the a/c system, one had no effect on me, but there was one on the aluminum a/c line, halfway between the heater box and the little a/c radiator that if i left it removed, the cooling fan would not shut off, even with the system removed, i plugged the little thing back in and it was fine.
Old May 22, 2006 | 11:34 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Do you have single or dual fans?Has any of the wiring or controls been altered by a previous owner?The control switch 1988CamaroSC is speaking of is in the A/C's high pressure line.It turns the fan(or passenger side fan if dual)no matter what the temp.But only if you leave you HVAC controls in one of the A/C modes or defrost.The fan relay's contacts could be welded shut(arced together).Best thing to do is trace the fan controls circuit to see if it's been altered or bypassed.
On having no heat,do you not get any even after the car's been run for awhile?The thermostat could cause some of your problem but you would eventually get some warm air out of the vents.You could have a problem with the vacuum controls for the HVAC.Do the vents open properly(what I mean is do you get air out of the correct vent according to where the control is set)?Also I'm not sure what type of heater control valve your year Camaro would have,again could be a vacuum problem.The heater core could be plugged,or bypassed.And the cooling fan(s) running all the time don't help either.
Old May 22, 2006 | 11:38 PM
Car: 87 iroc z28
i have the duel fans...i havnt really looked at the wiring yet but ill prolly do that when i get home from work 2moro. im not sure if ne ones modified it when i got it transfered to my name i had 2 and a half sheets of past owners..lol
as for the heat i drove for about2 hours yesterday with the "heat" on just to see if it would work and it got slightly hotter but not enuf to warm me up and yes it does come out of the right vents
*edit* when i got the car it was low on coolant and when i put the battery in wit the key on the fans came on.
Old May 23, 2006 | 09:05 PM
Car: 87 iroc z28
got a new rad cap and thermostat today put them in heat seams to work a little bit while idling but doesnt get much hotter while driving ...and only 1 fan is on all the time...havnt seen the second fan come on tho and i let it run for about 20 mins??? my heat temp seems to run lower then it did b4 wit the old thermostat. and the old one was stuck shut?? air pocket?
Old May 23, 2006 | 10:08 PM
Car: 87 iroc z28
hmm i seem to b gettin sum decent heat how...but only 1 fan is on(all the time) and the other one doesnt come on or at least i never see it come on??
my stat i got was the lower temp high flo one and my temp is stayin pretty low
normal ?? or am i just worrying 2 much?
Old May 23, 2006 | 10:16 PM
coolram62's Avatar
Engine: LU5 305 CFI
Which fan is running all the time;driver side - this is the primary fan or passenger side - operates when the HVAC is in A/C or defrost or engine temp goes above 230F.Take a look at this tech article and see if that helps.
https://www.thirdgen.org/cool
With the fan coming on at startup it takes longer for the motor to warm up.Similar situation to having an engine driven fan.And generally an air pocket will cause a motor to run to warm.
Old May 23, 2006 | 10:28 PM
Car: 87 iroc z28
ah thank you very much that article helped me alot ...i am running the 160* thermostat and my heat is getting luke warm..its all coming to me now..lol thank you
Old May 23, 2006 | 10:41 PM
coolram62's Avatar
Engine: LU5 305 CFI
You are most welcome I don't know why i didn't post the link to that article in the first place.Good luck and let us know your progress please.
sheachopper
Jul 31, 2019 11:27 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
