Please help!
Old May 26, 2006 | 05:53 PM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Please help!
The coolant in the overflow tank bubbles alot. Is this ok or is there a problem? It doesn't overheat it get's to about 220 then it goes down. I replaced the thermostat. I also flushed the radiator so I don't think it's plugged. Could my water pump be bad?
Old May 26, 2006 | 06:50 PM
alxtre99's Avatar
Car: 91' Camaro, 71' MERCEDES
Engine: Camaro 3.1L
are you loseing any coolent??
Old May 26, 2006 | 07:51 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
No, It's just bubbling in the overflow tank.
Old May 26, 2006 | 10:32 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
get a new radiator cap for it.
Old May 27, 2006 | 05:48 AM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
So then it's not my water pump? Man I hope not that's a pain in the butt to do. The rubber in the cap does look cracked and it's pretty old. Well I'll try that and I'll let you know. Thanks.
Old May 27, 2006 | 08:17 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
well I tried the radiator cap but that didn't work It still bubbled so I replaced the water pump and it stopped so I guess it was the water pump. Thanks for the help.
