31x19" fan shroud
Old Jun 6, 2006 | 09:13 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
31x19" fan shroud
ANyone made a shroud to fit a pair of fans on the 31x19" aluminum radiator? Just looking for ideas before I jump in head first.
Old Jun 7, 2006 | 10:00 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
I mounted a Flexalite #295 dual 13.5 fns with shroud. It is 17.5" X 27.5"--barely fits--had to trim shroud at bottom right (drivers side) to clear steering box, and had to trim the blades to clear the same.
If I had it to do over, would probably use a smaller setup that requires no triming. like the Flexalite #210--15.5X26" OR 2 independant fans with shrouds staggered--drivers side has to sit higher to clear front steering box.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
