ac overheating car issues
Old Jun 12, 2006 | 09:18 AM
89BlueRSCamaro's Avatar
Car: 1989 IROC-Z
Engine: 350-5.7L
Transmission: 700R
so here is the problem...just after i got my car working good i started using the ac cuz it is hot...well after a couple of minutes....lets say about 35 to 40 min of continuous ac use at full blast the car began to overheat...it then died out and i had to tow the car to my house.....well i cannot figure out what is wrong...the radiator has water and there are no leaks and i have no way or better yet do not know how to test to see if the ..........hhmm....forgot the name of the temperature thing that regulates the water and heat thing.......hhhhmmmm.....thermostat...there we go...how to see if it is bad...well i need help guys...any help please...no leaks that i know and the car has water........sssooo..i guess it is the thermostat....unless my water pump is not working properly...but i doubt that...well thanx
Old Jun 12, 2006 | 10:12 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Ive had that problem before.In my experience these cars dont handle hot weather very well unless the cooling system is in top condition.Mine did this last year.I put a new thermostate in it,made sure both my electric fans were working when the a/c was on.I hot wired them to the fuse box to run all the time dureing the summer(this will cut down on the life of your fans).make sure your radiator isnt cloged or in need of being rebuilt or replaced.It should be clean if not start by flushing it.Take the plastic piece off the top of your radiator and clean out between the radiator and that a/c radiator thing.(mine was filthy with leaves and stuff even had a bird lodged in the front).Have your fan temp switch checked,and make sure your temp gage is accurate.I did all this and mine stayed between 190 and 230 which is still hotter than i like at the top,but stop and go traffic and traffic jams in hot weather are horrible for our cars.OH YEAH,make sure your air dam is in place and not damaged.I just have to keep a close eye on my temp dureing the summer months in the south,especially in traffic.I ope you didnt do any damage when you overheated.goodluck
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
mustangman65_79
Sep 1, 2015 03:51 PM
mizz0313
Aug 12, 2015 06:45 AM
86Base
Aug 8, 2015 01:34 PM
