Fan Problems!
Old Jun 21, 2006 | 02:30 PM
dark_daku89's Avatar
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
Fan Problems!
hey,
i just recently bought a 1992 camaro rs with a 305 tbi, and i noticed when i bought the car that the fan was grounded so whenever i turned the key to the ON position, the fan started. Now, i notice that my car starts getting hotter faster and thats because the fan doesn't turn on anymore. All of the connections are good, but the only way the fan will turn on is when the A/C is on.
Any input would be nice and thanks in advance
Old Jun 21, 2006 | 03:15 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Hopefully whoever wired the fan to come on with the ignition put an inline fuse in and it's blown. When the a/c
is turned on, it overrides the radiator fan switch usually, but since it\s been tampered with it could be anything...
Old Jun 21, 2006 | 06:01 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
yeah there is an inline fuse but its been blown and it was also hotwired with a copper wire. maybe ill try to replace the fuse and then see what happens
Old Jun 22, 2006 | 02:04 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
well i changed the fuse and still no luck. It looks like the fan isn't grounded using the green and white wire, but it's hooked up to a 12 volt source. IF i wanted to ground it with a green and white wire, would it work then?
krisner89
Oct 10, 2015 06:03 AM
utfan01ss
Sep 28, 2015 12:17 PM
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
