Need sensor location help.......................
Old Jul 1, 2006 | 06:18 PM
recaroguy's Avatar
Old Jul 1, 2006 | 07:50 PM
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
recaroguy,
I don't know a whole lot about cooling systems but here is what I think. My '92 has 3 'sensors/switches' associated with the cooling system.
1. The CTS or Coolant Temp Sensor. This is what the computer uses to determine the engine temp and control the fan on the drivers side.
Mine was located on the front of the intake manifold and has two wires running to it.
2. The fan switch. Is used to control the fan on the passenger side of my car. I just bought a hypertech one (on at 200 and off at 185). It is located in the passenger side head between # 6 and #8 spark plug. It has one wire running to it.
3. Temp sender (I think). This is what sends the signal to the temp gauge.
It is supposed to be located in the drivers side head/block near #1 spark plug.
I think you need the temp sender. I just replaced the CTS and Fan switch but don't have any experience with the temp sender.
Old Jul 3, 2006 | 01:26 AM
recaroguy's Avatar
Old Jul 4, 2006 | 11:27 AM
recaroguy's Avatar
Old Jul 4, 2006 | 02:21 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Have you tried a thermostat ??..if its stuck open you will have the symptoms you described.
Old Jul 4, 2006 | 02:25 PM
recaroguy's Avatar
Nick McCardle
Sep 10, 2015 08:36 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
willyjoejr
Sep 3, 2015 09:26 AM
tonys91rs
Sep 2, 2015 07:07 PM
