Radiator hold down?
Old Jul 12, 2006 | 12:41 PM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
Transmission: Super T-10
Radiator hold down?
I put in an after-market aluminum radiator in my car. The stock fan shroud is now about 4 inches higher than stock. I am looking for some sort of bracket/brackets that I can use in place of the fan shroud, to hold the radiator against the support.
Any ideas or comments would be appreciated.
Thanks!
Old Jul 12, 2006 | 04:11 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Radiator Support
Hi,
What you might do is go to a good junkyard and see if
you can find a support from one of the earlier chevy
trucks that had the hold downs on the top crossbrace.
Was going to do this on my 87 Iroc and griffin radiator
but ended up altering my dual fan top piece to make
it work. Still may do that on the tank ribs as added
support. Can't remember what year trucks but sure
looked like they would work with a few alterations
HTH
jaykar
Old Jul 12, 2006 | 04:34 PM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
Good Idea, Jaykar!
Didn't even think of that.
Old Jul 12, 2006 | 07:53 PM
facelessnumber's Avatar
Car: 91 RS
Engine: L03 carbed
Transmission: 700R4, rebuilt+kit
Axle/Gears: 3.42, posi, disc
I bought a plate from Summit that fit pretty well for what I did:
http://pittman.ws/Camaro/IM001322.JPG
http://pittman.ws/Camaro/IM001319.JPG
http://pittman.ws/Camaro/IM001321.JPG
http://pittman.ws/Camaro/IM001320.JPG
This piece belongs on a Chevelle. They also sell one that goes on a 2nd gen F-body that's a bit wider and might look better, but I know this one works.
Old Jul 13, 2006 | 01:45 PM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
They don't make them for the 3rd gen. vehicles. The one you have has 3 hold-down bolts. Mine is 4 bolts and would also have to be a litte thicker and bent to go up and over the radiator and then be able to clamp the other side.
Thanks, though.
Just thought that someone has found a place that makes those same plates for a 3rd gen.
Old Jul 13, 2006 | 01:58 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
No place makes them for thirdgens any more. They haven't in probably 8 years. And even when they did it only worked for a stock rad anyways.
You either have to get creative and use the Chevelle/TA one and drill some new holes, get something from another car like the truck suggestion, or bent your own.
Old Jul 30, 2006 | 12:00 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
theres lots of possibilities for the hold downs
also the 73-80 trucks used the style like in the pics above, like in the second gen f bodies,
i have lots of them for 4 core radiators in the attic
i may use one of them for the 82, or maybe ill use 81-up truck ones
or just make out of aluminum stock
dunno yet
a tape measure and a marker are your friend
good luck
sheachopper
Jul 31, 2019 11:27 AM
mattcanty
Oct 12, 2015 11:08 AM
