High Temp
Old Aug 18, 2006 | 06:29 PM
NathanC5's Avatar
Car: 84 camaro z28
Engine: '89 L98 converted to CC Quadrajet
Transmission: '89 700-R4
High Temp
I have an 84 camaro. About two years ago I had an 89 350 tpi swapped in, but had it converted to carb. My cooling setup is the belt driven fan from the 84...the radiator I had with the 305..and a 160 degree thermostat. i had no problems until the past couple of weeks. when i get on the highway the temperature starts to climb steadily to 240 or higher. I flushed the radiator last night..put a new coolant tank and still the same.. and yes my air dam is intact..what can I do? what should my timing be set at with an 89 350 run by a ccc qjet?
junior419
Apr 7, 2025 11:35 AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
wisemanz28
Sep 20, 2015 01:26 PM
corey8084
Sep 17, 2015 02:56 PM
DARKmj16
Sep 9, 2015 04:07 PM
