tried everything and wont stop overheating
Old Aug 20, 2006 | 03:10 PM
michael john's Avatar
Car: 87 firebird
Engine: 2.8 Li V-6
Transmission: auto
ok guys i need some serious help! ok i drive a 87 firebird V6, its my everyday car. my car used to overheat until i put a new rad in. i drove it from oklahoma to missouri and it still was just fine. just a few days ago it started overheating again. so i said screw this and i replaced everything. thermostat, waterpump, rad, heater control valve, heatercore, hoses, i fushed it twice. and its still overheating. now its ok when its in idle but when i start going about 20-30 mph it overheats. the only thing i can think of is that when i had my old rad in the car my friend put some stopleak in it....but i flushed it....i dont have a clue in what to do now...plz help
Old Aug 20, 2006 | 04:05 PM
Dee555's Avatar
Car: 89 Iroc - 84 Trans Am -84 Corvette
Engine: 350 TunedPort
Transmission: 700R/T-5 World Class
Axle/Gears: Posi/Ausi/Disc/3.08
Yeah I had the same problem I put stop leak into my car and for a while it was okay then it started overheating. I flushed it and changed everything under the sun. The only way I was able to solve the problem believe it or not was with a complete teardown kinda sucks, to try and solve a problem with a simple solution then only have a bigger one snow ball on you.
Old Aug 20, 2006 | 07:42 PM
Car: 87 firebird
Engine: 2.8 Li V-6
Transmission: auto
dang well i hope it doesnt come down to that...i dont think my timing is off but ill double check to make sure
Old Aug 20, 2006 | 09:34 PM
irocgta's Avatar
Car: Iroc Z /Trans Am / Corvette
Axle/Gears: 273/308/323
Yeah I found that leak stop crap plugging up the pores to the heads. I don't recommend that crap. The best thing to do is simply fix the problem you'll thank yourself in the end.
Old Aug 22, 2006 | 01:51 PM
Car: 87 firebird
Engine: 2.8 Li V-6
Transmission: auto
well will fushing it a couple of times help?
Old Aug 22, 2006 | 03:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Is there an air dam underneath car? It should overheat worse at idle if it were a clogging issue shouldn't it? If it overheats while driving, sounds like the air dam is missing or something (assuming there is an air dam on the Firebirds - the Camaro's have 'em).
Old Aug 22, 2006 | 06:04 PM
Dee555's Avatar
Yeah I would go with IrocGta's conclusion because that stuff does have a tendency to block up the internal passages of the motor it happened to my 70 El Camino and my 97 Chevy Venture same problem of over heating once I used that stuff. You'll need a complete tear down and rebuild to get the car working correctly again. She probably won't be too bad in the winter so long as you are moving but forget about criusing around during summer months.
sheachopper
Jul 31, 2019 11:27 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
