block heater?
Old Sep 5, 2006 | 10:32 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
block heater?
So my car started leaking antifreeze the other day, and I discovered that my IROC had a block heater the kind that you plug into the wall well it was leaking so I took it out and stuck one of those expandable rubber freeze plugs in the spot. Now heres what im wondering is this going to affect my coolant flow at all cause its alot bigger and fatter than the old block heater
Old Sep 5, 2006 | 11:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It won't affect coolant flow at all. A freeze plug might be more reliable in the long term than a rubber plug.
Old Sep 6, 2006 | 10:31 AM
thats the answer that I was hoping for anythings better than that block heater does anyone know if thats a factory option? it was secrewed in some how, and all it had to protect from leaking was a o ring
Old Sep 6, 2006 | 10:51 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I believe it was a factory option, and aftermarket ones are a popular addition in cold climates.
1992Z28!
Nov 19, 2015 07:33 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Nervous2
Oct 8, 2015 10:53 PM
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
