Camaro Heater
Old Sep 14, 2006 | 10:24 PM
WaFFLesZ28's Avatar
Car: 1984 Camaro Z28, 1987 Z28 (R.I.P.)
Engine: 305 H.O.
Transmission: 5 Speed
Camaro Heater
Hey, I own a 84 Z28.. and the heating system doesn't seem to be working.. No heat or cold air comes out.. I also own a 87 Z28 and the heating in there works fine.. It's starting to get cold in Canada.. and my G/F is starting to freak out.. So I was just wondering which steps I would have to do to make the switch?
Old Sep 14, 2006 | 10:41 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Start with the panel, check vacuum lines and cainster, check fuses. If those work pull the dash and replace the heater core.
Old Sep 15, 2006 | 10:30 AM
If the fuse is good:
Take out the control head, and locate the brown wire that goes off and plugs into a similar wire. Attempt to unplug that connection. When you discover that it has burnt to a pile of ashes like they always do, you'll realize that you've found the problem. Cut the remains off, and replace it with a pair of BIG HEAVY-DUTY YELLOW INSULATED slide terminals. Not the ordinary little weenie ones; make sure they're the BIG HEAVY-DUTY kind.
I've had to replace that connector pair in I think I'm up to 7 cars in my immediate family, so far.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
