Easiest way to drain radiator?
Old Oct 12, 2006 | 01:35 PM
sam356's Avatar
Car: 1992 Z28
Axle/Gears: stock
I have a 1992 305TPI Z28. I have a hole in my radiator and am replacing it. Is there a good way to drain the radiator. It seems there is no plug and the metal piece directly below blocks where I would drain from the lower hose. Any suggestions or is this destined to be a messy task?
Old Oct 12, 2006 | 02:03 PM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
I have always just used one of those big black oil pans from our local auto parts store. Threw it under the car and pulled the lower radiator hose from the block side. Sometimes the rad. side when the smog pump is actually still connected. That ususually catches everything. Maybe a few drops splashed, thats all.
Old Oct 12, 2006 | 09:45 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
There is a petcock in the lower corner of the radiator. Just below the lower radiator hose, I think. Been a long time since I've messed with one. There is a small hole in the lower radiator support that it drains through. Unscrew it enough so it just pees out. One of those big catch pans like mentioned above should be more than sufficient.
Old Oct 13, 2006 | 01:35 AM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
yup,
, It's on the bottom passenger side of the rad,
Old Oct 13, 2006 | 02:13 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
What about the plug(s) on the block ? Haven't checked it out myself, do they go back in, or does one have to get some kind of replacements ?
Old Oct 13, 2006 | 02:53 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
They're threaded.
Old Nov 10, 2006 | 12:48 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Ah ok, thanks. That means I can remove them, drai nthe system completely, and flush it.
sheachopper
Jul 31, 2019 11:27 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
