New LSx fans...
Old Nov 5, 2006 | 03:14 PM
Zachnoel's Avatar
New LSx fans...
hi, i have replaced my old single fan on my 85 irocz with a dual fan set up from and LSx. the problem im seeing is that they seem to be sucking alot of energy. enough that i can see a dip on my voltage guage. so im wondering if that is normal or if there are other problems?
thanks
Old Nov 5, 2006 | 06:26 PM
redlsone's Avatar
My only way of thinking is 2 fans instead of 1 is going to use more amps usually unless they are very efficient aftermarket fans so you might see some dip. Are you treminals clean everything tight etc..
Old Nov 5, 2006 | 07:44 PM
Zachnoel's Avatar
right now i have both fans hooked up through a 25 amp fuse and it doesnt trip. do you know how many amps boths fan are supposed to draw?
Old Nov 5, 2006 | 09:22 PM
redlsone's Avatar
LS1TECH - Correct LS1 Fan Diagram Here
check this out and seee if it helps at all.
everything I have been reading on google for the lsx family says about a 40 amp fuse so far. It also describes how you have it wired and what gauge to use.
Old Nov 5, 2006 | 10:50 PM
MikeS's Avatar
I'm guessing that you have it wired up so both fans start simultaneously. That's a lot of current draw. Dual fan setups should have each fan controlled to start at different temperatures/conditions. That way you should never have both try to start at the same time.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Buggy Disaster
Sep 22, 2015 01:15 PM
