Easiest way to change thermostat
Old Dec 20, 2006 | 01:19 PM
3vi1p3nguin's Avatar
Car: 85 Iroc-Z
Engine: 350 4bbl
I tried searching but came up with nothing, so figured I'd ask. I need to change my thermostat from a 160 to a 180, and want to know the easiest way to do it. It looks like I could either pull the compressor, or the throttle body. A friend of mine put the 160 in when we were changing the water pump, so there was a lot less on the front of the engine then.
Old Dec 24, 2006 | 04:37 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Just follow the upper radiator hose from the radiator to the engine. Once you hit the motor there is the thermostat housing. Take the two bolts off and scrape the gasket off. Put in thermostat and bolt back down. Fill with coolant and yer good to go. 10 minute job.
POZ
Old Dec 24, 2006 | 09:31 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Yeah I don't recall pulling anything to get to the thermostat bolts.
Old Dec 24, 2006 | 11:40 AM
Car: 85 Iroc-Z
Engine: 350 4bbl
i was having trouble with it, and when i realized the right way to get it off i kinda had to smack myself in the head and go "der"
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
utfan01ss
Sep 28, 2015 12:17 PM
dutch930
Sep 11, 2015 06:58 AM
perZ
Aug 15, 2015 01:17 PM
