Help,Hot air coming out of vents
Old Jan 24, 2007 | 02:28 PM
Skull88's Avatar
Car: 1987 Camaro Z-28
Engine: 305 cu. in.
Transmission: Automatic
my car is throwing out hot air thur the top vents and the side and middle ones too. And all the switchs are off on the control, but my contorl to adjust the temp. is hard to move. Did something get stuck or what please help me.
Old Jan 24, 2007 | 03:45 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Heater
Never had that problem with mine, but the first thing, I'd
pull the vacumm line off the control valve above the
valve cover and see if your pulling vacumm when you turn the heat slide up.
Heater control valve could be jammed in open position.
If not that, remove the ac heater bezzel and see if its
linked up to the slider.
Just a thought.
Later
Irocing
Brinkkl2000
Aug 4, 2018 08:29 AM
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 11, 2015 03:17 PM
