HELP its fridged outside.
Old Feb 18, 2007 | 02:05 PM
90tararebird's Avatar
Car: 1990 trans am
Engine: 350 tpi
The heater blower stopped working. First thing i checked is the fuses and they are O.K. I need something else to check before i start taking the blower apart. Any ideas it has been under 32* out for a month and i'm sick of driving around and seeing my breath. Thanks.
Old Feb 18, 2007 | 02:14 PM
Phatfiddler's Avatar
Check the blower motor and relay. Mine went out not too long go and had to pick one up from Advanced Auto for $30.
Put the key in the ignition and turn it so that all of your accessories are on i.e. radio, dash etc, but dont start the car.
Open the hood, and stand near the blower motor assembly and have someone turn the air controls from on and off. You need to listen to a clicking noise to see if the relay is working.
If the relay passes, then it is almost certainly the motor that is not working, since the working relay indicates power is being applied to the motor. You can bypass the relay and hook the power directly to the motor to see if it works if you want, or pull the motor and apply power to it. Also, you can use a Voltmeter on the connections to see if power is being applied.
Old Feb 18, 2007 | 05:01 PM
Car: 1990 trans am
Engine: 350 tpi
Is the relay the little box thats next to the blower motor?
Old Feb 18, 2007 | 06:30 PM
Just follow the connector on the blower assembly until you get to the relay.
Old Feb 18, 2007 | 06:47 PM
Car: 1990 trans am
Engine: 350 tpi
O.K. i will check it in the morning, its dark and cold outside.
69GTOby
Apr 18, 2016 02:34 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Out-Cast
Sep 11, 2015 08:03 AM
Genopsyde
Aug 22, 2015 06:01 PM
BuddyLeeX
May 24, 2002 02:10 PM
