I need to delete the A/C evap core!
Old Apr 5, 2007 | 10:21 PM
RacerDad916's Avatar
Car: 89 Z28
Engine: 355 full roller, Brodix 10X heads
Transmission: Close ratio Muncie
Axle/Gears: 3.42/7.5
I need to know if anyone has a part number or pic of the heater box in the engine compartment that does not have A/C. When we took our car apart for the V-8 conv., the condenser core had a hole in it. I don't want to use the A/C, so I need to eliminate the evap core, and retain the heater core and fan. Let me know if any of you have done/seen this......
Old Apr 5, 2007 | 10:31 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: I need to delete the A/C evap core!
Search the classifieds you will probably find a lot of AC DELETE boxes to do what you want.
Old Apr 17, 2007 | 10:55 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Here ya go....a little expensive but BRAND NEW!
http://www.acdelete.com/pages/82-92_F-body.htm
Old Apr 17, 2007 | 11:27 AM
Teds92RS's Avatar
Car: 1989 Camaro IROC-Z
Engine: Lt1
Axle/Gears: Quick performance 9" 4.11
I can get you a refurbished box ready to install for $150 plus shipping
Old Apr 17, 2007 | 11:35 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Pull one from the junkyard for $30-50. I see them on this website around $50-80.
Old Apr 17, 2007 | 04:25 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
LOL, you guys are removing AC, and I am adding it back. You lose ZERO horsepower from having AC when it is not on, because the clutch free wheels. I'll take the 50 lbs of weight to arrive in comfort!!
Racerdad, you are a brave man with a T5 and the 7.5 rear. I would be worried about losing my leg when that T5 becomes a lot of high speed broken pieces. I had a fresh world class T5 behind my 327, but sold it because of my planned 383 upgrade. That stuff is on borrowed time!
Old Apr 17, 2007 | 04:57 PM
Teds92RS's Avatar
Engine: Lt1
My car isn't daily driven plus the a/c didn't work right, so I removed it. Plus, header install as well as spark plugs bloody knuckle free FTW as well lol
jaridjohn
Oct 5, 2015 07:01 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
