LS1 Fans!
Old Apr 6, 2007 | 09:28 AM
pinky93's Avatar
Car: 1989 IROC-Z
Engine: 5.7
Transmission: 700R-4
Axle/Gears: 9-Bolt Borg-Warner 2.77
LS1 Fans!
Thanks to researching your posts, I decided on installing some LS1 fans in my 89 IROC. I am going with a ProCharger and intercooler, so I think the OEM radiator will also be swapped for a Be Cool radiator along with the LS1 fans. Hopefully, this will allow me to avoid any cooling issues I am likely to run into living in Florida.....
I got the fans and shroud off of ebay for $127. Hopefully, I got a good deal.
Thanks to those that posted up info on this swap!
Old Apr 8, 2007 | 01:29 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: LS1 Fans!
From what I understand, the LS1 fan setups get pretty expensive, so the price you got sounds right, especially with the shroud.
Good luck, post back with your results!
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
