Cooling system running properly?
Old Apr 7, 2007 | 02:56 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
this is a BRAND NEW ENGINE...
how can I tell if my coooling system is running the way its suppose to be?
I have a 180* stat with the little holes in it...
I cant tell if its opening or not...I cant tell if water is circulating thru the mtor or not..
whats the right procedure so I can make sure eerything is running right?
I took out the heater bypass also...
I have the hose running from the RAD to one of the nipples on the heater core and the other nipple runs to the intake water hole right under the throttle body...I deleted the TB collant too.
I found that when I have the hoses connected to the heater core I get a leak inside the car passenger side...When I took the engine down last year the heater core WORKED PERFECT!...NOW why would it leak? Its only 2 years old...
I cant tell if water is even circulating thru it to the intake and going thru the motor like it should.
I cant tell if the thermo is opening.
I got a brand new radiator cap at 16lbs
brand new stock radiator.
Now when I bypass the heater core and just run the hose straight from the RAD to the intake fitting...the something got so HOT that the fitting blew apart and and SPEWED all my water out...I quickly shut the motor off.
This is the first start up of the motor...I hope I didnt screw anything it had been running for about 15mins anf the temp according the the gauge in the car got up to the mark inbetween 220 and 100.
can I have to much pressure?
hell I dont know
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
sreZ28
Aug 14, 2015 07:48 PM
