another question
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
another question
ok i need a new sensor, not sure what it is called. it is located on passenger side of block, between the last 2 cylinders, the clip broke off so i just have the wire hanging there. anyone know the name of this sensor? thanks in advance!!! -jon
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: another question
no it is right under the header, on the top of the block where the head meets the block
sry i just ment in that genral area on the block.
Im 90% shure that is the knock sensor but youre car is 7 years later than mine so i may be wrong.
this might help....it is just a 1 wire plug
yeah was the clip a round thing that you need to squese to dissconect it from the sensor?
dose the clip look like this:
https://ssl.shoalhaven.net.au/usgmse...3a2b9eb96ea6b8
not sure it has been broke since i got it
