Tested fan wiring, what can I conclude from results?
Old May 7, 2007 | 05:36 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
1986 Trans Am 305 LG4, single fan.
Fan isn't coming on, but does work with AC on. So did this testing...
Fan relay has these wires... Red, (2) Brown w/stripe, Green, Black
Jumped the Red and Black ----- Fan works
Grounded the Green wire (ignition on) ----- Fan works
Grounded the blue wire at the fan temp switch (ignition on) Fan does not work
So, it seems the fan relay is working and the fan motor is good. My problem seems to be somewhere between the fan temp switch in the head and the relay. Where does the blue temp switch wire meet up to the fan relay? What else should I check?
If I can't find the problem, I may just hook up the Hayden relay to the green wire, but would prefer the stock system to work.
Old May 7, 2007 | 05:46 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: Tested fan wiring, what can I conclude from results?
Maby it is just the switch in the RHS (passenger side) head.
Un-plug the wire that goes to that switch and ground it with ignition on and see what happens.
Old May 7, 2007 | 05:52 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
That's the blue wire I mentioned that I grounded with the ignition on. I should of said I unplugged the fan temp switch wire and grounded with ignition on. It didn't work, which is what really has me confused.
Old May 7, 2007 | 06:19 PM
VenomX-87's Avatar
oh ok, have you traced that wire see if it has broken anywhere.
i think that wire goes to the ECM, there is a way to check the computer with a paperclip (i think) it shorts the system and turns the fan on that way you know if the it is either the "switch to ECM" or "ECM to fan" that is stuffed.
Old May 7, 2007 | 07:00 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
No, I'll have to try and trace it tomorrow. Also have to find out where to do that paper clip test. Thanks.
Old May 7, 2007 | 11:01 PM
VenomX-87's Avatar
i took this from a different post
If you use the paperclip as you would read codes the comp controlled fan should run. The Diagnostic test terminal is the pin in the ALDL you ground to check codes.
I duno if it actualy works coz my car done use the computer anymore.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Jae992
Aug 27, 2015 09:07 AM
