overheating 89 IROC
Old Jun 3, 2007 | 07:51 PM
cdiedrick's Avatar
Car: 89 IROC
overheating 89 IROC
I own an 89 IROC that is a mess for wiring. I am no pro at it, but I can tell you that my electric fan does not work. Therefore I overheat when I am idling in traffic. My A/C is gone and from what I can figure out this is an issue when it comes to my electric fan. how can I fix this. I am no pro on wiring, but I am willing to try anything if it is explained to me in novice terminology. LOL. Relay is good, I am even open to a toggle, but I have no clue on how to do that. Any suggestions????????????
Old Jun 3, 2007 | 08:29 PM
kenf729's Avatar
Car: 1989 Camaro RS, 355, holley 650dp
Engine: flow master headers, 3" exhaust
Axle/Gears: stock
Re: overheating 89 IROC
I went down to the local auto parts store and bought a kit that has a probe that you push through the Rad fins close to the tank, wire it up and when the Rad gets hot the probe tells the fan to turn on, it only cost like $25 or 30 bucks very easy to install, and no worries about relays and all the other stuff. the Kit come complete with relay and wiring and instructions...very easy to install...
edit wanted to add
I think mine comes on at 190 and off at 160??? something like that.
Old Jun 3, 2007 | 10:06 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
How do you know the relays are good? Do you have a single or dual fan setup? Did the fan(s) ever work or is this problem new?
When I got my '89 some jerkoff had taken the stock dual system out and put in a single that was all busted up. I replaced it with a SPAL dual setup. That thing will suck the legs of your pants off!
Old Jun 4, 2007 | 07:34 PM
cdiedrick's Avatar
Car: 89 IROC
I have a dual setup. I replaced the relay so I know its good. it never did work and I never cared since I dont' live in a big city, so I don't sit in traffic normally. However my wife likes to drive the car also so it all just needs to work if you know what I mean, especially since I have headers with header wrap and a heatshield on the starter, but on a hot day the car needs to sit for 15 min or so in order to restart. So then that gives me a situation when I fuel up lets say, or go through a drive through.
Old Jun 4, 2007 | 07:51 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
If it never worked and you can be sure the relay works, I'd probably start looking at the fan setup itself. Have you ever tested the fans?
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
g.l.mos
Aug 22, 2015 12:02 AM
jbd1969
Aug 17, 2015 07:06 PM
mustangman65_79
Aug 11, 2015 03:17 PM
