What to clean water passages and cooling system with?
Old Jun 9, 2007 | 02:18 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I have quite a bit of rust in my block that is tainting my coolant. What can I use to run through the motor to clean out all the passages???
Old Jun 9, 2007 | 03:08 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Axle/Gears: 2.73 gears
Re: What to clean water passages and cooling system with?
i have herd baking soda is great, put like 2 table spoons in the radiator and drive the car for like a week and flush it all out, all the rust should come out.
Old Jun 9, 2007 | 06:01 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Thanks man, if I ever get the car running I'll give that a shot.
Anymore suggestions while I'm at it? Is there anything off the shelf I might be able to buy that would work for this?
Old Jun 9, 2007 | 08:42 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
no, i dont know of anything else sorry.
Old Jun 10, 2007 | 03:21 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I've used Prestones Super Rad. Cleaner before. Works pretty well. If it's really bad, though, an acid flush might be called for.
Old Jun 10, 2007 | 05:01 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
hey somebody told me that all that rust may help keep water leaks seald, can this be true?
Old Jun 10, 2007 | 06:14 PM
ReverendZ28's Avatar
Car: 1988 Z28
Engine: 350ci
Axle/Gears: Stock
Not so much the rust but some of the buildup in the coolant will block small passeges where leaks have formed... so sometimes when really flushing and cleanin your rad you might uncover leaks...
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
sreZ28
Aug 14, 2015 07:48 PM
