why am i overheating?
Old Jun 23, 2007 | 05:04 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Well i took my car to the track and every time it sits it overheats it has done this since the carb swap. It has a 6 month old radiator and water pump, 160 thermostat, and a hypertech fan switch and the other fan is on a toggle switch. Runs at around 160 or lower at driving speed then when im sitting still at idle it slowly creeps up to 240.
Old Jun 23, 2007 | 07:00 PM
ReverendZ28's Avatar
Car: 1988 Z28
Engine: 350ci
Axle/Gears: Stock
Re: why am i overheating?
Whats your fan setup belt or electric? it might be a lack of air flow, either your fan isnt pulling enough air through or your rad is blocked by somthing you didnt forsee... so whats your setup give us some more info it will be easier to diagnose...-RevZ28
Old Jun 24, 2007 | 12:24 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
its just a stock 89 serpentine setup with a carquest mechnicle water pump, stock dual fans and a stock replacement radiator.
Old Jun 26, 2007 | 01:58 AM
Car: 1988 Z28
Engine: 350ci
Axle/Gears: Stock
Are your fans pulling enough air through the rad to cool it down. What kinda of fans are you running are they stock? Or aftermarket.-RevZ28
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
