what dual electric fan.....
Old Jul 1, 2007 | 10:47 PM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
..should I be running in my LG4? Flex-a-lite doesnt list a direct replacement for camaros and I was wondering if anyone here had already found a good replacement. Definitly interested in dual fans only, thanks!
Old Jul 1, 2007 | 11:12 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: what dual electric fan.....
you can go to 4th GEN (LS1) Dual Thermo fans they seem to be the best upgrade with very little modifications to make them fit.
Old Jul 2, 2007 | 02:15 AM
TG Goose's Avatar
Engine: 355 SD TPI
I've heard about the LS/LT1 fans, but I also want to know what dual flex-a-lite fans people are running
Old Jul 2, 2007 | 03:18 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
I have the same question. I am replacing a 20 year old stock dual fan set-up in an `88 Iroc 383 TPI and want to know if I should hook up the new dual fans to the factory wiring or use new relays and install kits.
Old Jul 2, 2007 | 04:55 PM
VenomX-87's Avatar
make a small custom system and tap it into the old wiring that way you dont need to make a hole new fan loom and you can revert back to stock real easy.
Hope it helps.
EDIT: and yes i know fan 1 is hooked upto relay 2 (it was a stuff up when i made the picture 3 months ago).
Old Jul 2, 2007 | 05:04 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
I ordered a 12" Perma Cool #771-19008 from Jegs for $99 that flows 3000cfm, the highest for any single fan I found. I am only replacing the primary fan now, the fan for the air cond. was replaced a few years ago. My primary is the original, lasted quite a long time. Jegs has a better selection of fans than Summit.
TMZIrocZ350
Oct 7, 2015 12:09 PM
zman1969
Oct 1, 2015 11:09 AM
