Need AC help
Old Jul 5, 2007 | 12:04 AM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
Need AC help
ok, the pre owner had removed the AC from my car (evap can and compressor) I latter found a AC system out of a 87 camaro. Now here's my problem, I cant seem to find the plug in my engine bay, so I was woundering, dose anyone know were the plug is in the engine bay?
also, im going to try and track down some R-22 (I think thats the right one) but if that dosent work, im going to invest in some hot shot.
Old Jul 6, 2007 | 04:13 AM
Engine: 305 V8
Transmission: auto
Re: Need AC help
anyone?
Old Jul 6, 2007 | 07:20 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Need AC help
Originally Posted by CarterCarbureto
anyone?
Yes, take it to a A/C shop and convert to R134. R12 is a dead issue now for the present system. Went your route and it did not work. So if you want a working A/C you will need to spend some money. The A/C in almost all cases is not a DIY type of job.
Old Jul 6, 2007 | 04:53 PM
Engine: 305 V8
Transmission: auto
Re: Need AC help
Thanks for the , but that still didnt answer my question
"dose anyone know were the plug is in the engine bay?"
Old Jul 6, 2007 | 07:19 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: Need AC help
Should be located on the Passenger side right next to the heater in between the shock tower and the firewall.. If the plug you are talking about is on the condenser. The plug is approx 1 1/2 inches in diameter.
You really don't need to send to a shop to recharge your A/C. R-134a which is the preferred and easiest to get is found at any Auto Dept Store, Pep Boys, Autozone, Advance, Napa etc etc. The main kit contains a charging hose and possibly a guage. Usually 3 - 4 small cans will recharge a F-Body car. I can send pics of my plug if you pm me.
Old Jul 6, 2007 | 09:03 PM
DJP87Z28's Avatar
Re: Need AC help
R134 can not be used in R12 system as his 1987 has unless converted & purged.
Old Jul 7, 2007 | 03:39 AM
Engine: 305 V8
Transmission: auto
Re: Need AC help
I know were the plug for the canister is, but is that also were the plug for the compressor is located?
