TPI Fan switch?
Old Jul 11, 2007 | 10:08 AM
jcp74's Avatar
TPI Fan switch?
I have an 89 gta 5.7, I just bought the Jet gm fan switch. What side do I put this on? Each head has a sensor, But one has a green wire and the other a black one. Do I just match the wire colors? The Jet switch has a black wire.
Gonna flush the coolant soon and I want to get this thing in. Thank's for youre help!
Old Jul 12, 2007 | 02:16 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Re: TPI Fan switch?
The pass side head is the fan switch.
The driver side is the coolant temp sensor that goes to the gauge.
Old Jul 12, 2007 | 03:31 PM
jcp74's Avatar
Re: TPI Fan switch?
Thanks!!!!
Old Jul 12, 2007 | 03:58 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPI Fan switch?
Be VERY careful when you remove the plug on the passenger side. It gets very brittle over the years and is likely to crumble when you touch it.
Old Jul 12, 2007 | 09:32 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: TPI Fan switch?
What temp (on/off ) fan switch did you get and are you also changing the thermostat?
Old Jul 19, 2007 | 05:51 AM
jcp74's Avatar
Re: TPI Fan switch?
I'm not shure about the on/off temp, I'm changing the thermostat to a 180 deg.
Will do, Thanks !!!!!
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
86IROC112
Aug 17, 2015 02:00 PM
TA8487
Aug 16, 2015 12:21 PM
Sanjay
Aug 12, 2015 03:41 PM
