cylinder head pipe thread size?
Old Jul 27, 2007 | 10:24 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Hey, what size is the pipe thread hole in the cylinder heads? This is for the temperature gauge on the drivers side.
I want to replace the plug on my passenger side with a thermal switch for electric fans, and I want to get the right fitting (before I remove the plug to measure it)
Old Jul 27, 2007 | 11:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: cylinder head pipe thread size?
1/2 or 3/8 NPT.
Old Jul 27, 2007 | 11:34 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
3/8" npt IIRC, there's only 3 choices typically, 1/4" ; 3/8" ; 1/2" all NPT threads from any hardware store.
Old Jul 27, 2007 | 11:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Some heads are 1/2, some are 3/8.
Old Jul 28, 2007 | 12:23 AM
Sonix's Avatar
Car: 1982 Trans-Am
Yea, I knew it had to be 3/8" or 1/2" NPT. I was at Gregg distributor buying a thermal switch and the 1/2" looked too big, but I was unsure, so I didn't buy it. I don't want to have all my coolant in a bucket when I realize I bought the wrong one.
These are 416 305 heads.
Thermal switch - would I be able to nab one at the wreckers? Any thoughts on closed circuit temperature? I'm thinking 190°F or so, with my 180°F t-stat.
toronto formula
Nov 10, 2015 06:17 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
knight72
Aug 10, 2015 09:32 PM
