Temprature Switch Wire Help
Old Aug 4, 2007 | 06:55 PM
88Camaro_04's Avatar
Car: 1988 Chevrolet Camaro
Engine: 5.0L 305c.i. V8
Transmission: TH-700R4 Automatic
Hello all, i've had some cooling fan issues recently. I've replaced the fan relay, fan motor, and had to do some wiring work and I still can't get the fan to kick on when it's supposed to. I did have a toggle switch set up but i'd like to convert it back to the factory specs. I didn't realize that the Temprature Switch had anything to do with the Fan and when I found it, I realized that there was nothing hooked up to it.
While looking on Autozone.com I found two types of Temprature Switches, for all I know I have the wrong one on the car. So which one do I need?
http://www.autozone.com/R,APP264427/...ductDetail.htm
http://www.autozone.com/R,APP227180/...ductDetail.htm
I really appreciate the help, hopefully I can get this issue fixed and then tear into the other electrical issues that the car is having.
Old Aug 4, 2007 | 08:11 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Temprature Switch Wire Help
the first sensor shown is for the temp. gauge . between #1 & #3 plugs on drivers side . the second one is the one for the fan between #6 & #8 plugs . lots of luck . temp. issues with our cars have always been a problem .
Old Aug 5, 2007 | 07:06 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Do a search under "cooling" and look for "Willie`s Total Fan Control". There is a great deal of info about cooling on 3rd gens. in addition to Willie.
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
