A/C CLutch wont engage
Old Aug 23, 2007 | 10:15 AM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
Just put on a new compressor, lines, receiver drier, low pressure cutoff, ac relay. but no go. I did everything that I was told to do and no luck need help.
Old Aug 24, 2007 | 03:51 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Re: A/C CLutch wont engage
get out the tester and start following the power.. check for 12v at the relay then the switch then the compressor itself... might even try taking the connector off the low side pressure switch and jumping it with a paperclip.
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
mfp189
Sep 27, 2015 09:25 AM
