Coolant Leakage - Should coolant reservoir have a seal?
Old Aug 30, 2007 | 03:56 PM
Soenneker's Avatar
Car: 85 Firebird
Engine: V6 2.8L
1985 Firebird (Non Trans-am)
First Question: Should the coolant reservoir cap have a seal on it? I see it does have a gasket on it. But should it be air tight? The threads on the cap are warn, and the top (where it should connect with the gasket) has a dent. I can push on the reservoir, and I can hear air being pushed out and sucked in when i let the reservoir return to its normal shape.
Second Question: The coolant doesn't leak when the engine is cold, but when it starts to get warm it drips (every 15 seconds) from the rail underneath the radiator. Where should I first look for leaks? - Or is this from the coolant reservoir cap?
Also, the engine currently runs at 160-180 degrees when operating at normal, and reaches 220 sometimes when I accelerate at higher speeds, but then drops back to 160-180.
Jake
Old Aug 30, 2007 | 03:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Coolant Leakage - Should coolant reservoir have a seal?
No it shouldn't be sealed. Look for a leak on the rad somewhere.
Old Sep 1, 2007 | 10:15 AM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
maybe even from the water pump???
sheachopper
Jul 31, 2019 11:27 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
