Single to Duel fans help!
Old Sep 25, 2007 | 09:43 AM
ChampionN84's Avatar
Car: 91 Camaro Z28
Hello Everyone,
I have a 91 tbi car that i am converting to a TPI with dual fan setup. I had the harness converted to tpi but the fan setup is still for a single, how can i properly go from my one connector to a duel fan setup.
Thanks in advanced!
Old Sep 25, 2007 | 10:21 AM
Russ-So Cal's Avatar
Re: Single to Duel fans help!
If you don't have the Helms manual for your car, get one. The wiring is different from tbi to tpi including the iwring to the ecm. If you have the Helms manual, look at the wiring prints and wire it the way the factory did.
Old Sep 26, 2007 | 01:54 AM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
I converted my 86 TPI single fan car to dual fans. See the post of how it was done in this section, dated 7/27/07, titled "OVERHEATING PROBLEM FIXED." The system works perfectly. If you wish to persue this design, and have questions, let me know, and I will try to answer them. Good Luck. Charles
sheachopper
Jul 31, 2019 11:27 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
dusterbd
Sep 29, 2015 08:40 AM
